That was me.
Yes I have the Atom with ProAcs itās my hearings thats changed again . They do work well but I am now having more tinnitus than before and I am more sensitive to hi frequencies. My room really exaggerates this.
Not going to give a heart for that, as it would be cruel.
Are you going to look at other speakers, but I imagine it is a challenge until you get them in the room and give them a good listen.
No the ProAcs are not the issue here really,
Any speaker I have tried has this affect in my Room not much I can do. These have been the best yet and I really like what they do with majority of my music. Itās just some goes awry.
michael bought a turntable ?
Sorry Tom ā your post got caught up in a bunch of others I moved out of the āWhat are we listening toā¦ā thread. I moved it right back.
But yes, it appears Michael did indeed buy himself a turntable.
So it was Michaels fault
He bought this fu⦠turntable just to bring some confusion
Main issue is my listening position which I cannot change without a major overall of the room and wiring. So that aināt going to happen. 2nd where I can place the speakers is a problematic area. Itās an alcove, with windows behind them and this creates a nasty resonance. I canāt get the ProAcs as close to the wall or in the best position for them due to the curtains behind them and it stops Mrs Gipsy from being able to open the windows which is more the issue. Floor doesnāt help either with reflections. The whole room is a compromise that I just canāt do anything about. I used to be able to deal with it but as my hearings changed itās become more of an issue especially this last year. I might just have to live with DSP and live with its limitations.
I do not have DSP, but sometimes I get ideas. But I do not know about the limitations. I do not want to be a pain but can you describe in 10 words those limitations pls. Thanks
A few here.
It canāt help a null, which is where you get bass suckout or other frequencies due to Room mode cancellation and SBR. Only modifying the room with bass traps and other panels or insulation can properly negate a null.
You move your speakers you have to recalibrate for it. I have to move mine at certain times of the year unfortunately.
Limits the listening zone to be the best so often off axis listening is not the best.
Uses more cpu so more power.
It doesnāt always sound better with some music and robs it of some mojo.
But the returns overall are greater it just takes some getting used to. Iāve fluttered back and forth a lot.
A do move speakers and subs a lot. Usually if I jump from classical/jazz to electronic Iāll get too much base, and the flip side.
It is a software only, or hardware?
It depends you can buy minidsp hardware or use Roons DSP engine, this uses a lot more of the cores cpu so need a core capable and obviously it will consume more power as itās working harder. NuCs though if using one are not hugely power hungry but given the state of things less is more.
I guess I am somehow under Paulās spell (PSA), he said he does not like room correction.
So I need a software and the measuring mics to make some custom filter and load that in Roon?
You have to do the readings yourself but there are some services that will create convolution filters to load into Roon and will customise them to your needs. Home Audio Fidelity is one such service. Thierry who owns it is amazing. He knows what is doing I use him as heās very patient getting them just right for you. He provides an easy to use app to take the measurements to but you need to get your own mic. Or you can use REW app to measure and create yourself. There are others popping up all the time.
Thanks a lot. Iāll have a look at the options
I downloaded Housecurve on Friday and used it to set up a convulation filter for the Bedroom setup. To be honest it took longer to read the instructions than it did to take the measurements (saved the sound file to the Local Library and played on loop to get an average of 6 readings) and create the filter.
Thought the result sounded good playing at native bit-rates and have been upsampling to DSD128 since Saturday.
Oh, thanks⦠I have to get an iOs to try
Cheers. Just a note that if you are playing DSD Files then turn off the convolution filter. Had a couple in a short playlist, choked the processor trying to do 100,000+ taps and ended up having to forcequit Roon.
My bad, I think!!
I have issues with what itās doing going by the images used on the app page. It shows adjusting nulls with a positive gain which is a big no no. You can do that in REW and it can make things a hell of a lot worse. Also it offers no phase and time adjustments which HAF do and this makes a big difference you canāt get with eq alone.
Iāll have to do a bit more reading to take that in.
So, even if it sounds good. It may not be great for the system. Is that the gist of itā¦
