Missing audio devices after updating to Roon 2.0 build 1470 (ref#LP0R5U)
· Something else
All my audio devices are missing after updating to Roon version 2.0 build 1470.
Running core on iMac - macos - Sequoia 15.0.1. Remotes running on iPhone and iPad with ios version 18.0
Hello @Donald_Schlack ,
Can you please navigate to macOS System Settings > Privacy & Security > Local Network , and make sure Roon is allowed. If it is already enabled, toggle it off and on again. Then reboot your Mac, and see if the same issue persists.
That worked! Thanks so much noris!
n/a
Did you try the same solution that helped last time?
