Missing Bit Depth Conversion Step in Signal Path (ref#HHTSQD)
The Signal Path is missing a bit depth conversion step before Headphone EQ without SRC.
not relevant
Hi @Adeeb,
Thanks for reaching out to us to ask about this issue. Can you provide us a screenshot of your DSP settings that you’ve set up for the iPhone?
Is the signal path you’re showing what you expected to see? If so can you please provide a screenshot of the signal path you have with the missing bit depth conversion?
These are the DSP settings for this muse preset. Very simple. Apart from the missing bit rate conversion the rest is as expected.
Note that if I enable SRC or Headroom Management then the first bit depth conversion correctly appears.
This was already shared in the original post.
By comparison, the first bit rate conversion appears correctly when SRC is enabled, as I mentioned above.
Hi @Adeeb,
Thanks for providing those details. I’ve added these details to a bug report for our development team. I cannot give you an exact timeline on when a fix will be released but when it is we will let you know here.
Hi @Adeeb,
I wanted to let you know that a fix for this issue has been finished and should be released in the next few updates. Please let us know if the signal path issue is fixed after the fix is released.
