Hello i’m now using the test period.
But something is odd with Roon for me. i can find my USB connected Meridian Prime! (Device not found)
any tips?
any tips?
Hi Emanuel,
Give this a read and see if it helps.
Also, can you post a screenshot of your Settings > Audio page?
Cheers, Greg
Hi Emanuel,
Just to confirm, are you able to play music through your Meridian system? I see it as a zone.
Do you still want to be able to play music through your system output attached to your core?
If so, can you tell us about your setup?
Cheers, Greg
My ID41 works (way way faster with Roon then with Sooloos)
But it would be nice to be able to use my Meridian Prime that is USB connected to my Win10 Pro computer on a x99 motherboard. and i use the Prime daily so there is no problem there and the Roon version is 1.2
Did you install DAC Drivers https://www.meridian-audio.com/wp-content/uploads/2015/11/Meridian_USB2_audio_v1.68-19_driver_installer.zip.zip ?
