Hi
Is any difference between sound quality when I use roon from moode or Ropieee?? Both use RAAT so I think is without difference…? I use Allo USB bridge Signature as bridge
I have the Allo USBridge Sig as well. I found that it sounds best with DietPi…ideally a clean install with no Allo GUI. Extra background processing seems to harm performance a bit.
I’m extremely happy with Ropieee. It’s easy to install, runs from RAM, is optimized for Roon, has great support, and probably a few other pluses if I think about it longer
Same here, I use Ropieee exclusively as it gives me greatest flexibility with the DAC and analog path.
