QNAP HS-453DX
Ethernet, no VPN, RT-AC88U
DCS Bartok
not relevant to the issue
When using Speaker Filter in DSP, MQA does not play on Bartok.
Same here. but only when in speaker settings I have distance applied. When only gain is applied I still get the mqa
with distance:
without distance:
Not very helpful for you, but just to know that I get the same order in the path (distance after restore)
system
(system)
Closed
4
