Hi
Probably showing my lack of knowledge and how the DSP engine works, but here goes. My question is. I have a MS600 connected to my amp via analogue. Can I do anything in the Roon’s DSP engine to improve the sound?
RGds
Martin
Hi
RGds
Martin
Depends what you mean by “improve”.
The MS600 upsamples. You could try different upsampling filters in Roon and send 88/96 to the endpoint which will then simply be converted to analogue. You might prefer a different sound.
You can also fiddle with the parametric eq in Roon if you want a different tonal balance.
Personally I liked the sound of the MS600 as is very much. I felt it to be quite neutral and faithful to the source. YMMV
Thank you very much.
