I have started to merge albums to get over all the errors on multi-disc releases in Roon’s awful meta data for classical music.
Although I intend to use nothing other than Roon, I do not want to spend any time making changes to a proprietary format.
Can someone please explain what happens when you are making amendments in Roon?
As a side note I am incredibly annoyed any of this is necessary since my tags are perfect but the way Roon reads it messes it up. J River shows it perfectly by contrast.
Roon does not modify your files in any way, other than if you choose to delete the files from inside Roon.
Have you read this article? I’m guessing something about your tags or folder structure is making Roon think these are separate albums, but let us know your files appear to adhere to those guidelines and we can take a look.
The problem is my entire collection is ripped under, say C/Beethoven Symphonies/CD1 then C/Beethoven Symphonies/CD2 etc. So as a test I just moved everything into a single directory, and it improved the situation, in that it grouped the discs together, but now look what has happened!
Yeah, this is the problem – Roon will assume you want these imported as separate albums, since they aren’t stored in a way that indicates the albums belong together.
There are a few ways to get this right, the most obvious being:
C/Beethoven Symphonies/Album Title/CD1/01 - Symphony No 3.flac C/Beethoven Symphonies/Album Title/CD1/02 - Symphony No 3.flac
… C/Beethoven Symphonies/Album Title/CD2/01 - Symphony No 5.flac C/Beethoven Symphonies/Album Title/CD2/01 - Symphony No 5.flac
You could also try this format:
C/Beethoven Symphonies/Album Title/01 - 01 - Symphony No 3.flac C/Beethoven Symphonies/Album Title/01 - 02 - Symphony No 3.flac
… C/Beethoven Symphonies/Album Title/02 - 01 - Symphony No 5.flac
But this isn't going to work:[quote="DelPrado, post:4, topic:23908"]
[/quote]
We've made a lot of progress on Classical music, but there's absolutely still work for us to do. That said, we have incredibly rich data about the Beethoven symphonies in your screenshots, but you're not going to see any of it if we can't identify the content.
The vast majority of multi-disc sets are identified by Roon without any need to manually group the discs together – this leads directly to good identifications, which leads to good metadata in Roon. Unfortunately, if your files are stored in a way that Roon can’t understand, you’re not going to get good results.
I guess Roon treat your hierarchy as C:/Album Artist (ie Beethoven Symphonies)/Album Title (ie CD1)
I also think this is how Roon should behave. Your example is not consistent with Roons way of treating folder structures, and I suppose it is not consistent with your own collection.
Roon does not have AI - I think. Therefore it looks for consistent folder structures and can not “guess” where in the folder structure to look for i.e. Album Title.
But, on the other hand, there is also the metadata tags. Folder structure is not everything The question to ask yourself when tagging and structuring is perhaps: how would Roon know?
Well, so much for a long, non-authoritative, rambling answer
I cant see a difference between the examples still. When I wrote Beethoven Symphonies above I was not referring to a folder which had performances by loads of people, in which I add every recording of Beethoven Symphonies, it was a specific cd set a complete cycle of Beethoven 9 discs.
Therefore, to be highly specific, and to give a concrete example, I rip as follows:
c:/Beethoven 32 Piano Sonatas - Gulda/Disc 1
c:/Beethoven 32 Piano Sonatas - Gulda/Disc 2 etc
What exactly do I need to change that too so Roon can read it?
Sorry @DelPrado, I just talk from a long experience with how computers and organisation works. I do not dare to give direct advice on Roon - since I am a newbie specifically on Roon. Perhaps someone with more Roon experience can answer this
According to Mikes example Christian - that is not necessary. And for my undesirable as I have ripped thousands of cds according to EAC best practice which does not include embedding cd number in the filename
My assumption was that the /Beethoven Symphonies folder contained many albums – if that’s correct, and you have multiple CD1 folders at the same level, its going to be much more difficult for Roon to group these folders into proper multi-disc albums that can be identified.
On the other hand, if the /Beethoven Symphonies folder only contains a single album, then CD1 and CD2folders are fine.
It might be easier for me to understand what’s going on here with the media in front of me @DelPrado. Do you have Dropbox (or similar) that you can use to send me a multi-disc album that’s not being imported correctly?
Hey @DelPrado – I took a quick look at the media here and I’m not sure there’s much we can do. Roon uses a pretty finely-tuned process to make sense of both file tags and folder structure and group discs into albums. At least for the content you sent I don’t think either is consistent enough to give good results automatically.
Neither album you sent has folders called Disc 1, Disc 2, etc. I don’t believe we currently recognize folders called Vol1, Vol2 but I can check – my guess is that that convention is more commonly associated with distinct albums, and we probably got complaints that we were merging multiple distinct albums into a single multi-disc set (ie, the opposite of what you’re looking for). If you change the folder names to the Disc 1 conventions I mentioned, this will probably work.
Additionally, these files don’t appear to have consistent disc number tags (also called media number). You can see here on this track from disc 3:
Unfortunately, without consistent folder names or disc number tags, Roon isn’t going to be able to automatically group these sets into discs. You can group them in a few clicks in Roon, or you can update your files to a more conventional format, and then rescan.
