I have no other Airplay endpoints so can not test.
Yes the Klipsch Stadium worked flawless in the beginning too it is only since a few weeks it gives me the continuous problem. Literally every song so can not use that any longer for Roon untill I find a solution.
It seems the reset for a Klipsch Stadium takes 30 sec no power instead of the usual 10/15 seconds most of the devices. So I left it unplugged for over a minute and now as by miracle it is still playing after minutes so fingers crossed it keeps playing.
So I thought it was solved but it seems the problem is back.
I need to keep resetting the Klipsch Stadium. Sometimes once or twice a day and other times once every two days. I can not detect why (or after what) it occurs nor is there a clear pattern.
Exactly, a reset works for a certain time and then it stops again . Roon keeps playing but no sound after a fe seconds. As mentioned no patterns are detected. As for now it appears ad-random,
did not discuss with Klipsch but have tested it with my iPad and it plays music stored on that device without a problem over Airplay so have to assume it related to Roon
I think the next step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
