Hi. Roon has stopped working for me. No problems at all until today.
Screen says there are no audio devices. I go into the settings and the Devialet is not showing. Also none of my music is there. My own FLAC files not there or the albums I have added from Tidal.
I have done the usual reboot a few times and made no progress.
Any help appreciated
Not including your Roon or PC setup, your network should be comprised with a Internet Modem and also maybe a Router (unless the Modem has this built in). Sometimes but not always there might also be another box called a switch.
Power cycling would mean disconnecting the devices from the electrical source (electrical wall outlet) for a few seconds, then plug in back in. Give it about a minute to power cycle everything back up. After that check your internet to see if it is back up.
I have to pop out for an hour but when i come back I will try and turn everything off at the wall and leave for a few minutes and try again. Thanks for your input
Well I unplugged everything for the time I was out. Plugged it all back in and it is now working again.
It is now scanning all my music again so hopefully no further issues.
Thanks for the help
Good to hear that everything went back to normal, @Womaz.
I think yes, your backup contains the snapshot of your DB. But I would also recommend giving these two articles a read: this one is about duplicate albums and this one which is about backups/restoring a backup.
Thanks I will look at these, however I have set it to not show hidden albums, but it is still showing the tracks in the album section. I think it may be tracks that I have favourited in tidal
What a frustrating day with Roon. Now my iPad won’t connect to the roon server . So nothing has changed with my set up yet today I have had all of the above issues
I hope this is just a one off
