My Live radio does not always work
NUC7i3BNH 8GB RAM
ASUS RT-AC68U, ETHERNET, NO VPN
MUSICAL FIDELITY MX-STREAM, DAC QUESTYLE CMA FIFTEEN
5000
Some radio stations do not work, for example:
information:
Playback was interrupted because a track failed to load
The radios work in other applications
Try these links? Do they work for you?
Dance One Radio: https://s9.myradiostream.com/:14296/listen.mp3
USA Dance Radio: https://stream.rcast.net/66781
Costa Del Mar Deep House: https://radio4.cdm-radio.com:18012/stream-mp3-Deep
Deep House Ibiza: https://radio4.vip-radios.fm:18015/stream-128kmp3-DeepHouseIbiza
Note: I’m not sure if the TuneIn integration still works or is completely broken meanwhile (there was a reason for Roon Labs to create their own Radio Library after all). Users may be better off using a working and tested stream URL instead of the TuneIn integration.
Searching for stream URLs might be beyond what a common user is willing to invest, so please post request to add radio stations to Roon into the respective forum category #live-radio.
Hello @Tomasz_Andrejewski and welcome to Live Radio.
As @BlackJack says, TuneIn integration can be problematic with a few streams of a certain format. It usually works, but not always. The radio curators are always happy to help and add such stations to the Room database where possible.
In your cases, I have added
Dance One Radio
Costa Del Mar - Deep House
Deep House Ibiza
Searching with the magnifying glass is the easiest way to find these.
Unfortunately, I haven’t been able to find a stream for USA Dance Radio that Roon will accept. I’ll inform the Devs about that one.
I have managed to find a working stream for
USA Dance Radio. US only.
BrianW, BlackJack thank you very much for your help.
Everything works perfect.
I can listen to my favorite radio in the best ROON.
