MacBook Pro 16 Go 1600 MHz DDR3
Wifi
5000 tracks
My roon is tolatly blocked.
Wifi
5000 tracks
There was an issue loading your library.
Please complete the template thoroughly, so you may be assisted. However, the message usually means the database cannot be used. Do you have a backup of the database? If so, try restoring this. Also, have you used Time Machine recently to restore your Mac?
Hi,
I renamed the Roon folder Roon_older et reinstall roon.
It seems to work.
DA
If the problem persists, you may have a failing SSD.
