Could you provide Sound Card Driver installed to ROCK? My Sound Card is RME HDSPe MADI FX.
Hi @Tony_Yeh
Sorry but I don’t think ROCK supports any sound cards apart from what is built into the supported NUC’s listed here:
https://kb.roonlabs.com/Roon_Optimized_Core_Kit#More_about_ROCK_39_s_hardware_support_
Yep, ROCK is meant to be an appliance OS with strict hardware specs. While, the devs are gracious enough to let users install it onto other hardware, they do so with the understanding that they will only support ROCK installs on the specified hardware.
