Nad products with hqPlayer
looking for some guidance if anyone has any regarding nad m66 with hqplayer. I was thinking of playing with it but im sure nad max out at 192khz, is there any point in me getting involved with hqplayer??
Yes, you can still for example upsample 44.1k and 48k by 4x, which is already notable step. It is of course less than what can be done in some other cases, but still improves quite a bit more than doing nothing.
You can try it out for free and then decide if it is worth for you.
id like to try it if i could, is there a code or coupon to use to try it out? i appreciate your time…
You can just download and test it without any coupons or codes. It works for 30 minutes per run and then needs to be restarted for another 30 minutes and so on. License key removes this limitation.
i appreciate you
thanks
