Network Details (Including networking gear model/manufacturer and if on WiFi/Ethernet) NAS Ethernet and WIFI
Computer Windows drive with DAC USB cable to Oppo DAC, DAC also has own driver but is not MQA apparently.
It did not find all of the music filed on the folders I set up.
I am a savvy computer user but not on networks. I do not understand your instructions on how to set up path to NAS. I do not work in the NAS QNAP software environment but use Windows. My NAS works fine in all other applications just using Windows commands. Your instructions are written for computer/network professionals not ordinary people.
My Synology NAS has the name SynologyServer.
I have all my music related files in the folder NAS Music
I ask it to watch the specific folder DailyMusic.
To add this network drive location, go to Settings>Storage
+Add Folder
+Add Network Share
Network Share Location: \\synologyserver\nas music
Enter your username for that server and folder if you have it set up that way.
Enter your password for that username
I left WorkGroup blank
Hit Add Network Share and this will be added to the list of networked folders. Then click on that network share and select any subfolder. In my case this is DailyMusic.
Hi Scott,
I have edited your post to reflect the correct syntax of your network share location.
This forum application has also its own syntax when writing messages.
You can always put these kind of strings between backticks (-> `your string` ) to prevent this.
The \-character in this community is also used as an escape character and might be stripped away…
