Need help on ROCK for USB noise
NUC10i5FNH with Rock and Roon 1.8
Connected to ethernet with Netgear Wi-Fi router
Celsus Sound Companion One USB DAC
Very loud noise when connect the DAC with NUC by USB port. Try both front and back sides USB ports are the same result. But If connect the DAC by plug into my Macbook Pro and play music, noise disappear.
Companion One also support Wifi connection, I put it to join the same network and Roon able to find it. When play music, the quality is crystal clear.
My NUC got the power by plug into an US wall socket
Hey @Jacky_Chan,
I’m so sorry it took us this long to get back to you :pleading_face:
I appreciate you testing different ways of connecting your DAC and sharing that information with us. Are you still experiencing loud noises when connecting it to your NUC?
Thanks in advance :pray:
