Need Help: Sonicorbiter wont connect to Roon
How the heck does this work? Over the past week roon has had trouble finding my smallgreencomputer sonicorbiter. after searching it reconnects until it fails again. now
it can’t find the sonic core at all. Have booted, rebooted, changed cables. yes, the internet is working fine. please help.
Hi there! To create a new topic, please click “Get Help” below and enter your details in the form.
:point_right: Get Help With Roon
This helps our team gather all the necessary information to solve your issue as quickly as possible. Thank you!
Hello @conundrum
Thanks for reaching out! Based on the diagnostic data enabled on your account, it looks like your Roon Server is up and running — the process started successfully and is currently bound to the local IP address 192.168.0.7.
Let’s run a few quick checks to better understand why your SonicOrbiter isn’t being detected:
  1. Check web access
    • Open a browser on the same network and go to [url=http://192.168.0.7]http://192.168.0.7[/url]
    • Do you see the Roon Server (web UI) page load successfully?
  2. Check file sharing (SMB)
    • Try accessing the server via \192.168.0.7 from your computer’s file explorer.
    • Can you connect or see the folders?
  3. Network and connection
    • Confirm both your Roon Core (server) and SonicOrbiter are connected to the same subnet (e.g., 192.168.0.x).
    • Make sure there are no VPNs or guest networks enabled on your router.
    • Try temporarily disabling any firewalls or network security tools.
    • If you’re using Asus AiMesh or similar, check that both devices are connected to the same node (main router, not satellite).
  4. Reboot sequence
    • Power off all related devices (router, SonicOrbiter, Roon Core).
    • Start your router first, wait 2 minutes.
    • Then power on the Roon Core, followed by the SonicOrbiter.
  5. If you will have access at some point in time, please try to go to the Roon → Settings → General → Logout and log in again.
Please let us know the results of steps 1 and 2, and whether the SonicOrbiter reappears afterward. This will help us pinpoint where the connection is failing.
hello vadim and thanks for your help.
I don’t quite understand the steps in #1 but 192.168.0.7 does bring up the sonicorbiter.
I did all of the rebooting as described. multiple times.
roon is connected but there is a red dot above the three lines on the upper left of the home page and a circle keeps spinning.
last night when I went to bed roon kept asking the question “are you on the internet” or something to that effect. yes, I was, and everything else in the house was functioning.
I just now attempted to play something via roon and it began to play.
however, the circle keeps spinning:
please expedite this process. now roon keeps asking if I’m online. yes, everything else in the house working fine. can we talk?
the latest error message is "metadata improver: paused. roon having trouble verifying connection, etc. connection is good. have rebooted numerous times. have checked with internet provider. all working on my end.
Hi,
Check out this page from the Roon’s Help site …
Hope it helps you to resolve this issue, if not Roon’s support team will be along to help.
@support The Roon version is current, is this issue the Roon Core or something else?
I have the latest version of roon 2.55 build 1559
Hi @conundrum,
From the linked Roon help page I shared …
  • Update Roon :white_check_mark:
  • Reboot :white_check_mark:
  • Resolve Networking Troubles :white_question_mark:
How did you get on with the last item in the list?
Below are the areas it advises to investigate … it will help Roon support to know what you have / have not attempted.
  1. Change the DNS that your network is using
  2. Disable IPv6 on your router and server
  3. Remove any managed switches, WIFI repeaters, or powerline adapters from your setup
  4. Disable any VPN, firewall, and antivirus running on your server
roon is current. I’ve rebooted multiple times. and I have no idea how to change DNS and disable ipv6. I’m an old man. there are no vpn, firewalls, or antivirus. roon has been working flawlessly for years. nothing has changed on my end. I need help. thank you.
ps- everything else on the network is just fine. thank you.
Hello @conundrum,
Thank you for the update.
We do not offer phone support, but we’ll be more than happy to assist you right here on the Community website.
When we troubleshoot through the Community, it ensures that our entire team has access to the discussion and can weigh in as needed — including our Support, QA, and Development teams.
From the diagnostic data enabled on your account, we can see multiple warnings related to metadata server access:
[1008] 10/22 21:49:41 Warn: [metadatasvc] FAIL [5] https://metadataserver.roonlabs.net/md/4/updatemetadata?uid=&lid=&token=&metadataid[]=7b004d5430303437343334383037&metadataid[]=7b004d5430303437343334383039&metadataid[]=7b004d5430303437343334383131&2&tidal=max (179ms) Unauthorized
[1009] 10/22 21:49:41 Warn: [updatemetadata] error in updatemetadata: Result[Status=Unauthorized]
All of these errors are marked as Unauthorized, which means your authentication token may have expired.
Let’s refresh your credentials to reauthorize access:
  1. Open Roon → Settings → General.
  2. Click Log Out under your Roon account.
  3. You’ll be redirected to the login page — please sign in again using your usual credentials.
This process is safe — your database and settings will remain intact. However, as a best practice, we always recommend creating a manual Roon backup before making any account changes (just in case).
Once you’ve logged back in, please check if the issue persists and let us know the results.
a very wise person suggested deleting my roon account and installing a fresh version. once logged in to the new version I was up and running. his was the correct solution.
