Need help with Chord Mojo/Poly combo and DSD 256 over DoP
Windows 10 64 bit
Roon V1.6 B 416
Direct wired PC to Linksys AC1900
Chord Mojo/Poly
I can get all files to work over USB at DSD 256 but when connected with Roon using the Poly the settings show a max of DSD 128. Just wondering if Roon can output DSD 256 with DoP over DLNA and it’s just a setting I’ve missed? If I can get DSD 256 to work with my Poly I will buy the life sub
This thread seems to say it is.
@Timothy_Hughes is that right?
Hi @Tony_Arnoldi,
I just checked with the hardware team and they have confirmed that the Mojo/Poly combo only supports DSD128 through Roon. This limitation may be different when connected via USB as you noted and as in the thread @ged_hickman1 linked.
– Noris
