Have some problems with live / non live tracks in roon.
I detected a couple of albums which are flagged LIVE while it’s tracks aren’t flagged LIVE at all while being so.
Looks to me as if object-oriented programming didn’t happen here, since an album isn’t a LIVE version if all it’s tracks aren’t at all? Might be that I manually flagged the album to be a LIVE version since it’s an unindentified ablum. But even then … shouldn’t the FLAG if set for the album also set the track to be live?
I also got albums which have a couple of LIVE tracks, which is ok that the album wasn’t flagged LIVE.
But it would have been nice if the tracks would be.
So I’m after a task to mass correct these.
From theory I would have simply renamed the titles (trailing "life ") so that could filter for these.
But then I found no ability to mass select and edit these in bulk form. Set LIVE to YES.
Is there really no way but to manually do this on a track by track task? next to 1000 wrong ones seen so far.
Help appreciated.
