Thanks Chris… It’s weird as I downhrafed the firmware in the NAS to a February version and now it’s working but it refused to connect on the current version. I’m wondering if Roon has kept up with the QNAP firmware since it’s had 2 new tweaks since Feb.
The first thing I notice is that this NAS is a bit underpowered compared to what we recommend. Not sure if that’s the issue here, but that could be playing into it.
Since experiencing this have you tried rebooting the QNAP? Sometimes if Roon is stuck initializing it means the Core machine is in a bad state and a reboot will often help.
I have rebooted and the firmware downgrade fixed the issue. Are you sure Roon is working properly with the latest Qnap firmware ? Could there be a handshake issue ? Thanks
