Network audio connections disappeared from audio output menu (ref#2BJ9SE)
· All network audio connections (HomePod, Auralic, etc.) suddenly vanished from the audio output menu. They are no longer listed in the settings and cannot be activated.
· Roon is on my Mac, no vpn activated but installed. router live box 7. ne recent change
Hello @erwan.bories,
Thank you for reaching out.
Since you’re running Roon on macOS Sequoia (version 15), it’s important to note that this release introduced stricter and less transparent local network permission handling compared to previous macOS versions. When these permissions are blocked or partially reset, network audio devices (AirPlay, RAAT, etc.) can disappear from Roon entirely.
Please check the following:
  1. Local Network permissions
  • Go to macOS System Settings → Privacy & Security → Local Network
  • Make sure Roon and Roon Server are allowed
  • If they are already enabled, toggle them off and back on
  1. Restart the Mac
  • After toggling the permissions, reboot your Mac
  1. Restart Roon Server from the menu bar
  • Click the Roon Server icon in the macOS menu bar
  • Choose Quit Roon Server
  • Then start it again and reopen Roon
After this, please check Settings → Audio again and let us know if the network outputs reappear.
