Network connectivity issue with error code 504 and failed auto-configurations (ref#AEFC3N)
"ipv4_connectivity": {"status":"NetworkError","status_code":504,"error":"error code: 504
"external_ip": {"actual_external_ip":"183.ddd.aaa.hhh","actual_external_ipv6":"null","router_external_ip":"null"},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"status":"NotFound"},
"multinat_autoconfig": {"status":"Failed","error":"Network Trace Failed"}
· I have a primary router and a mesh network. No vpn. Unable To set up roon arc
Hey @Ramesh_vasudevan, welcome to the community, and thanks for sending over the diagnostics.
ARC is reaching the internet, but the router side is not completing automatic port mapping, so we should check the manual network path next. The most useful place to start is our guide on ARC Port Forwarding, since mesh setups often need a little extra care around routing, subnets, and port forwarding.
Could you confirm two things for us: the make and model of your primary router, and whether the mesh system is in bridge/access point mode or routing mode? Also, if you have already set up port forwarding for ARC, let us know if you set it up on both routers, as both need to be configured if not in bridge mode.
Once we know that, we can narrow this down and tell you the next step to try.
