Since today in the morning the new firmware “Snowmass” for PS Audio DirectStream DAC is available in the PS Audio download section
It’s next level!
It’s unbelievable what Ted conjured up here.
Snowmass V2 (ver 3.0.4) for PS Audio DirectStream DAC (Senior) is available in the PS Audio download section.
## Fixed Issues (Source)
- Users couldn’t update bridge firmware on 3.0.0
- Bridge update now displays upgrade percentage until completion
- The Bridge II would set the volume to 50 on initialization
- Volume level will restore to 25 on reboot
- Locked/Unlocked button didn’t hold settings on reboot
- Locked/Unlock button now controls Attenuator setting from remote IR and setup menu
- Bridge II Album Artwork reloading on every song.
## Updated Features
- Added Button on Setup Menu that Toggles Volume controls between “Fixed” and “Variable”
- When button is set to “Variable” Max Volume is displayed to the Left.
- The “+” and “-“ buttons will affect the Max Volume of the DSD as it has always done
- When Button is set to “Fixed” Max Volume is switched to Fixed Volume.
- This is the ONLY place where users can change the volume (Up or Down) while in “Fixed” mode
- The DSD will save the volume at the time of toggling the button to “Fixed”
- If the unit is in Fixed Mode upon power cycling it will rest to the same volume.
- If the unit is in Variable Mode upon power cycling it will rest to volume level 25
XMOS was not fully USB 2 compliant, leading to timing issues with bit depth changes when using ROCK or some other modern Linux distros.
Owners of Mytek, Audiolab, Wyred for Sound and some other XMOS-equipped DACs have reported noises or loss of sound until they restarted their DAC.
Roon contacted DAC vendors with info on this known XMOS issue.
Did PS Audio remedy this problem?
