Win 11 64 bit Home. (upgraded a couple months ago), library on local PC (F:/Music/)
Intel i7-8700 3.2GHz
32gb RAM,
Netgear AC1750 v1 router
Running cabled ethernet to DAC from router.
PS Audio Directstream Jr. DAC - ethernet cable
JBL Link 300 - wifi
local PC where Roon installed
Several Google Home devices
65,000
When I start Roon it says “Add your music”. This screen shows the existing and previously functioning path to my music.
Then I click continue and see “Add a music service”. I have none and click “No Thanks”.
Next screen shows “Set up your Audio devices”. No Audio devices are listed so I click “Finish”.
Goes to screen My Albums and states “You don’t have any albums in your library”.
Also shows “No audio devices found”
I click “Add music” and attempt to add my library source F:\Music. It shows red warning “This folder has already been added”
I click on “Manage Audio devices” and the Settings/Audio screen shows no devices.
I click to “HOME” and it shows 0 artist, 0 albums, etc.
Setup / “Search for Roon OS Core” shows continuous “progress icon/speaker animation” no results.
TROUBLESHOOTING_______________
I confirmed all files are at F:/Music.
Rebooted PC, network router (several times)
Renamed RAATserver folder, no change, then reversed back to original)
None of my Playlists show.
