Thanks Harry,
I’ll send that info to Magna HiFi who made the streamer I’m using. It’s strange that it works with a 2B Pi but not the 3B when I used the old RoPieeeXL 4.017 software. Tried the Pi3B using the latest beta version 2022.3.0134, no luck with that either.
Just downloaded the current RopieeeXL. My USB DAC is iFi iDSD Pro. I could use UPNP fine but Roon can’t see my Audio device. I did try 2 different sdcard, same issue.
When going to Roon extension tab, I could see Roon does see Ropieee, see screenshot.
Any idea why Roon doesn’t see my USB DAC? Thanks.
Hi Lawrence, welcome to the forum. Are you using a hat with your Pi?
Hi,
Nope, no HAT. Just USB out to my DAC. As mentioned i turned on UPNP and it works fine so am not sure why Roon doesn’t see my DAC under Roon’s Audio tab.
Moode audio also works fine w Roon.
