Modem → TP Link C50 → PC (core)
→ TP Link C50 → Uptone Etherregen → Sonore Optical Rendu / cambridge audio CXN2 v2
PC, Rendu and CXN as described above, all wired connections, fiber into the Rendu. All devices have received their static IPs through the TP Link C50 router
Used to connect Qobuz and also a small library < 2000 tracks
Had pleasant 60 trial with Roon after purchase of SOnore Optical Rendu. All worked well, used mainly HQPlayer (via Rendu) or the Rendu directly to play Qobuz music via Roon. But did a lot of AB testing playing via PC or CXN. Just before end of trial I purchased a monthly subscription. Few days or many hours after becoming a subscriber (dont remember exactly) Roon started crashing. It would crash everytime I was using HQPlayer and would restart it (the hqp). Also would crash often with other devices. Tried rebooting everything in the network chain, etc, didn’t help. Read about reinstalling Roon, so I tried it. After reinstall it quickly open the first time showing eveything as before for the first time I opened it. Then it closed and when restarting Roon, all was gone. I had not performed a backup (my fault, newbie to Roon). Now I have no folder selected, no Qobuz and no devices showing. I tried to perform a backup (even though now there is nothing to backup really) and there is an error backing up database. Everytime I try recycling all network, restarting windows etc, nothing changes and yet I have to show music folder and connect Qobuz again upon starting Roon, and device list shows nothing. Also tried uinstalling Avast or leaving its firewall off, and also tried restoring Windows defender settings ( I had recently upgraded to avast premium so it was my first suspect for causing the issues.)
I admit I probably lost 60 days worth of DSP settings , several adjustments to my Qobuz Playlists, etc, but I can live with that if my devices appear again and backup works so I can perform scheduled ones from now on.
By the way, just confirmed that even though I can connect to Qobuz gain, it doesn’t seem to be working properly. It will show some of the playlists in My Qobuz (not all of them, just the most recent ones, maybe the ones created after I first intalled Roon, but can’t be sure). It does not show anything under the tabs “new in Qobuz” , etc. WHen trying to show the actual songs in any of the “my playslists”, Roon will crash. Don’t know if this is because no device is connected anyway
updated to Roon 2.0
nothing changed. My Roon core IP is alright, but when try to add HQPlayer (same IP as has always been) it just doesn’t go. Still crashing when trying to access Qobuz (and I mean just display songs of any playlist). Not only I will unfortunetly not be able to renew my subscription but also feel I wanted my money back since I had just a few days of working Roon after i subscribed.
Really glad I didn’t pay for the whole year though
Please accept my apologies on behalf of the team that you’ve endured such a long wait time for a response. I’m flagging our @accounts team since you mentioned that you’d barely been able to use Roon during your initial month of subscription.
In the meantime, tech support has attempted to pull logs from your Windows Core device, so we can pinpoint the source connectivity issues plaguing your network. However, your device appears to be offline. Please open Roon and leave it running at some point in the next few days; the next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers.
You can also use the directions found here and send over a set of logs manually via our File Uploader?
Once the tech support team has logs, we’ll be equipped to more thoroughly investigate and provide immediate troubleshooting steps. We’ll be watching for the diagnostics report in the meantime.
I hope Roon has performed better over the weekend. I wanted to check in regarding the issue you reported.
We haven’t received automated diagnostics yet, but we’ve reset the request to expire after a longer window, so as long as you log in to your Core and connect to the internet within the next few days, the tech support team should gain greater insight into the connectivity issue affecting your endpoints.
Have you had a chance to upload logs manually in the meantime by following these instructions and dropping them here?er Without logs, we’ll have only dim insight into what might be causing the network dropouts.
I wanted to check in concerning the issue you reported since the team’s automatic log pull went through over the weekend.
The Cambridge Audio networked endpoint appears to be retaining connection during playback, and the frequency of network dropouts appears to have reduced significantly since your initial report last month. Has your own experience confirmed our reading of the logs in this regard?
If issues come up again, I recommend you take the following step to refresh RAATServer:
