Hi! What’s not quite right with Roon? · None of the above quite fits
None of the above quite fits · None of these quite match
Tell us what's going on · No Audio Devices Found (USB Topping D90)and UI Jitters
Tell us about your home network · Mac Studio M4 USB connection to Topping D90 - no networking involved. Have Fort Collins fiber, Ubiquiti Cloud Gateway Ultra, Ubiquity Pro Max 24.
noris
January 30, 2026, 12:28am
2
Hello @Hagen_Finley ,
Thanks for reaching out. macOS Sequoia (version 15), has tighter (and more obfuscated) network security settings than preceding MacOS versions.
Can you please navigate to macOS System Settings > Privacy & Security > Local Network, and make sure Roon and Roon Server are allowed.
If it is already enabled, toggle it off and on again. Then reboot your Mac, and see if the same issue persists. Let us know if this helps!
Noris,
Those security settings were not allowed so I changed that and rebooted.
That seems to have fixed things but in the past Roon would work for a while and then the devices would drop out. If that happens I’ll let you know.
Thanks for your assistance!
Best,
Hagen
system
(system)
Closed
January 31, 2026, 9:31pm
4
