Hello, when I want to select audio device, the screen flashes and then it goes blank, so I cannot select any audio device, I don’t know why…, it was working fine before.
Win 10 64 Bits
WYRD / Schiit Jotunheum USB
Help.
Win 10 64 Bits
Help.
paging @support
Thanks for reaching out, @Miguel_Angel_Herrera! We appreciate you sharing your report with us.
First, may I ask that you please provide a brief description of your current setup using this link as a guide.
Next, so we can gain some additional insight into what you’re experiencing, please verify the following:
Dylan
Did you get a Windows update? I would double check to verify that all Firewalls and Anti-Virus allow Roon. Also, the latest version 1803 caused my Schiit USB drivers to completely fail. I had to revert back to Windows v 1709 to get it working again.
-Roon lasted version.
-Windows 10 / 64 bit.
-Schiit Jotunheim amp / dac USB
-Intel i7-4790K./ 32 RAM /
-2 TB HD Internal storage.
-22500 tracks aprox.
Yes i updated Win, how I do that? (add Roon to Firewalls)
The best way to test if this is the issue is to temporarily disable your firewall and see if the behavior changes in Roon. If it does, you’ll want to make sure to add exceptions in your firewall settings for Roon and RAATServer. There’s a pretty good article about how to do this that you can check out here.
If there is no change after disabling your firewall I’d also recommend temporarily disabling your antivirus and see if that yields any change.
Have you tried rebooting your Core machine yet?
Thanks,
Dylan
I temporarily disable my Firewall, and it’s the same, no devives found , I don’t running an Anti virus,
Thanks for giving that a try, @Miguel_Angel_Herrera!
Next, let’s try this:
Before anything, please create a backup of your current Roon database.
Once you’ve created the back up of your Roon database please close all active instances of the application and reboot the machine hosting your Roon core.
When the machine hosting your core is powered back up I would like you to please test with a new RAATServer folder in place.
RAATServer_old
Once you have renamed your “RAATServer” folder to “RAATServer_Old”, please relaunch the application, and confirm if you are still experiencing the issue.
Dylan
Hey, thank you Dylan,
But I just fixed it, unplugging and plugging the USB in a different port,
That does it for me,
Thanks,
The error came back! I don’t know what to do
Sorry to hear that is has returned! Do you have a different USB cable you could try? Since switching the port seemed to work for a while it sounds like there may be something occurring with the USB connection.
-Dylan
I try this, and it works now, thank you!
Let’s see if stays working I keep you posted
Cheers,
