My Nucleus is connected to my Iphone. I want to connect it to my DAC so I can play over my sound system. When I go to settings no sources appear that I can enable. The sound section will not appear when I go to settings. How do I fix this?
Can you please post a screenshot of Roon > Settings > Audio from your iPhone or another control app that you have?
Sorry but I can’t do that as Roon>Settings>Audio doesn’t exist.
Audio does not come up when I go to settings. That’s my problem.
The Audio tab does not exist at all?
Like if you go to Settings,
and then scroll the tabs to the right,
this is not there at all?
Got it, many thanks!
And are you now able to connect it to your dac?
Yes, thanks
