Hi,
I installed 1.8 and am running build 783. I am having issues with not seeing any Audio Output devices. Roon Remote is indicating “No audio devices found.”
I am using a 432 EVO Aeon music server which is running Roon Core and uses LMS as the player. It appears that Roon is not listening on port 9000 which is the LMS port. Nothing is listening on that port, so LMS players won’t connect to Roon. See below:
Normal:
[root@vortexbox ~]# netstat -p --listen -n |grep 9000
tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 5795/RoonAppliance
Your server:
[root@vortexbox ~]#
= no output
Any ideas how to resolve this? I tried rebooting the 432 EVO several times, no luck. I also tried Turing off, then turning back on Squeezebox Support in my Roon Remote app. That doesn’t resolve it either. This is the case whether using Roon Remote on my iOS app or the Mac version of Roon software.
Is there a way to force re-install Roon 1.8 Core? Not sure what else to do that this point. Thanks for any assistance/advice.
Jeff
