jrd1975
#1
Hi
I have an Allo USB signature with a TP Link Bluetooth 5.0 adapter plugged in.
When I run Ropieee XL 4.017,
I don’t see the Bluetooth option. For reference this is the first time I’ve attempted to use the Bluetooth functionality.
Any help would be great
jrd1975
#5
I think it’s this, Raspberry Pi Compute Module 3 Plus Rev 1.0
jrd1975
#6
Which I am now suspecting doesn’t support Bluetooth 5…
spockfish
(Harry ten Berge)
#7
RoPieee only supports bluetooth on the Pi 4.
jrd1975
#8
Ah, ok. Thanks for letting me know. I’ll need to get a newer Pi.
@spockfish
Hi Harry
I do have a Pi4 and the Bluetooth setup isn’t showing. What do I need to do?
Bevan
Knarfhe
(Frank Hestad)
#10
Same issue as Bevan. Have a Pi4 rev 1.5, but no bluetooth tab.
I’m pretty new to this, so unsure if i need to enable it somehow or how this works?
spockfish
(Harry ten Berge)
#11
It’s probably related to a new revision of the Pi 4 that’s not in the whitelist of RoPieee.
However, this is not something that will be fixed: a new release of XL is imminent and that release will drop support for bluetooth.
