No Signal Path indicator light
I do not see a Signal Path indicator light on my system. Running Roon through ZENith Mk3
The Zenith is your Core I suppose? What are you using as remotes? Can you post a screenshot?
iPhone is my remote
On the phone, it’s on the Now Playing screen. First, tap the bottom play bar to go to Now Playing, then it’s bottom left. (It only lights up when you are playing something, else it’s grey)
Thank you !!
