No sound devices on network
Since yeterday Roon doe not “see” my network audio devices; It ony sees the sound ouputs on the core pc; Coul this be to do with the laatest Windows Update ?
Check your Windows firewall settings for Roon application.
Done that earlier
Did you just turn the firewall temporarily and see if they appear. You need Roonserver, Roon, and Raatserver allowed in the firewall. Most users don’t check for Raatserver.
Edited the title and moved to #support
A cruriosity: 5 out of the 6 devices are controlled by Sonos. They qre visible qnd playable on the Sonos app on my phone but are invisible to Roon.
No replies ???
What happened when (and if) you followed @Rugby’s earlier suggestion?
It would also help further diagnosis if you gave full details about your setup and network. Thanks.
I suspect you are onto something. Windows Defender is not active because Avast is proving a firewall.
My setup is:
Core Asus Vivo
Everything cabled
1 Sonos play 3
2 Linn LK100 + Sonos
3. Sonos Play 5
4. 2 Sonos play 1
5. Sonos + Hollywood mini 100
6. Linn Akuraatee
You werer right. I have disabled the Avast firewall and reset the Defender. All back to normal!
