i really need some help and i do not find your support system helpful! My Roon is clearly working but no sound is coming out. However, when i put the live radio on the sound is fine.
Hi Kevin,
I have shifted your post into Roon Support where it will be investigated. Can you describe your setup as set out in this post ? That will help @support track down the issue.
