No sound from Creative XFI sound card[Solved-ish]
I have installed Roon, I see my music collection in it, I have named a Zone for this PC as “workshop,” in Audio Setup I see the Creative XFI WASAPI twice, and Creative ASIO once. Setting any of these to ENABLED and playing a track from my library I see the played time of the track advancing but there is no output from the Creative XFI card.
I also have WINAMP on this PC. I have set the DirectSound output to CREATIVE XFI. Using Winamp I can play any stream or select any file I like, it works fine, I can hear it. Hearing it is the objective here… can’t hear anything from ROON.
How do I get ROON to output audio from my Creative XFI?
See =>
MY PC (workshop):
Windows 10 Pro/ 64, i7-4790K, 16 GB RAM, 1 TB data drive, 512 GB SSD boot drive, gigabit ethernet to my Roon Server
ROON SERVER
Windows 7 Ultimate/64 ,i7-4790k, 32 GB RAM, 10 TB Raid 5 storage on Adaptec 3405 controller.
did you try undoing the current Xi fi, workshop, and activating the 2nd one. I had that happen with a xi fi card, and there was an entry for each audio out option, I tried them all until I found the one which worked for the output I was using. Also, notice you are a Neuromancer fan.
I just tried it again, and this time it worked. Have no clue as to why. I chose the same exact settings as I tried the first time. It did not work that time, but did work this time. OK, that’s good, it works, sound comes out, that’s what I want. Ha ha ha, to answer the “why” question- that’s an extra charge.
Yes, that machine is named Wintermute. It was either Wintermute or “GSV No More Mr. Nice Guy”
I shall rename my server “Anticipation of a New Lover’s Arrival, The”.
My work domain I have named The_Slow_Zone. At home, I have The_Beyond.
