What’s happening? · Other
How can we help? · None of the above
Other options · Other
Describe the issue Roon appears to be operating normally, except there’s no sound. Makes no difference whether I play from my own library, Tidal, or internet radio. Playing from another source (phono) works fine. My Roon Nucleus communicates via wifi to a Bryston BDP2. Any thoughts?
Describe your network setup Internet provider router etc.
daniel
(Daniel)
March 3, 2025, 7:20pm
2
Hi @Kelly_Doerksen ,
Thanks for reaching out to us about this issue. There’s a few things I want you to check to narrow down what the problem is.
Can you please provide a screenshot of your signal path when playing to the BDP2?
Do you have any other endpoints you can test playing to such as the system output on your remote device?
The next time you try to play to the BDP2 can you let us know the date, time and track playing? That will help us look for issues in your Roon logs.
Problem solved with a complete system reboot. Please close thread.
daniel
(Daniel)
March 5, 2025, 8:13pm
5
Great we’re glad Roon is working properly for you now. I’ll close the thread out for you.
