I have everything set up and working well. However I noticed when using Roon Radio every now & then a track looks to be playing but is silent. When I look at the signal path the silent tracks are Qobuz FLAC 192kHz 24bit 2ch.
According to the NAIM manual, my version of the superuniti should be capable of playing 192kHz, 24bit streams.
Can anyone help please?
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
#2
Do you have your audio device setup to allow 24/192 streaming?
Not sure if that would stop it playing entirely or not but certainly worth checking!
See screen shot, under settings:audio: device setup: max sample rate.
Hi Greg, I am using optical. I just checked my Naim manual and it does say:
6 x S/PDIF:
1 x coaxial BNC - up to 24bits/192kHz
1 x coaxial RCA - up to 24bits/192kHz
3 x optical TOSlink - up to 24bits/96kHz
1 x front panel mini-TOSLINK - up to 24/96kHz
So it looks like you may have found the solution.
Unfortunately looks like i am going to have to buy a converter from either the stereo BNC/ TOSlink to an RCA
AceRimmer
#8
Or much easier and cheaper is limit it to max 24/96 in Roon audio settings.
Very much doubt you will be missing much as only occasionally you see 24/192 on Roon Radio and at least this way it should play them
