No sound playing Tidal 192/24 Flac Bluesound Node 2i Chord Mojo 2(ref#TJOS36)
· The issue *only affects one file *format.
Which format is giving you trouble?
· FLAC
· It is connected through a different device (e.g Rasberry Pi)
· Only one output type is affected while the other output type works as expected
· Bluesound Node 2i feeding Chord Mojo 2
Wired network, NUC Core, Bluesound wired
Example is No Name by Jack White.
Room remote appears playing, no sound produced, lights on Mojo 2 suggest no signal.
Other Tidal Files inc Flac Ok.
Playing back the same album without Roon, Tidal Connect to Bluesound Node 2i and out to Mojo 2 plays back fine.
Tried turning off headroom management and convolution filters no difference.
Tidal quality set to Max in Roon settings. Changing this to High allows playback.
Bluesound firmware up to date. Roon up to date.
Hi @Aidan_Nolan,
Thank you for the report. We’ve activated diagnostic logging to take a closer look.
We see some forcible network closures of RAATServer and some bandwidth allocation dropouts with the connection to Tidal during playback of 24/192 FLAC files. The prebuffer is sleeping in read. This occurs with lower-quality formats, as well, to nearly all endpoints, but Roon recovers playback in almost all cases.
Do you have any stateful firewalls or antivirus software that might be restricting RoonServer and RAATServer’s network access? What about traffic management settings in a router or managed switch (upstream of RoonServer) that might be throttling bandwidth?
In the meantime, we’ll take a closer look with the team to determine next steps and keep an eye out for your response.
Hi @connor,
Thanks for your reply.
Not that I’m aware of. I’ll log into the NUC at the weekend and have a look.
There’s an unmanaged switch between the Node and router. I can try with this out of the network chain and see if there’s anything.
Hi @Aidan_Nolan,
We’ve taken a deeper dive with our QA team.
The conclusion is that RoonServer’s ability to buffer content from Tidal’s servers is compromised.
Curiously, we see the buffer slowing intermittently during playback of lower-quality files, including 44.1kHz. These errors accumulate sufficiently to dispose the Zone because it’s not receiving an audio stream.
You’ll need to check the router’s settings to see why RoonServer’s connection to Tidal might be restricted or throttled. If there are Quality-of-Service or traffic management settings, verify that RoonServer’s IP address is prioritized.
Hi @Aidan_Nolan,
I wanted to check in before this thread auto-closed. Are you still encountering the same issue with 24/192 FLAC files on this endpoint?
Hi @connor ,
Thanks for checking in.
The issue still persists unfortunately.
Playing right now at 19:50 Dublin time for example.
I had a look at the configuration page for my router at the weekend and I do not see anything configured that is suggestive of throttling.
Is it worth checking anything else?
The NUC is running Windows.
Hi @Aidan_Nolan,
Simplifying your network overall would be a useful thing to troubleshoot. Can you get a basic hardwire ethernet connection from your Roon Server directly to your router, as well as to your Node 2i?
Hi @benjamin,
This is essentially the setup already.
Roon server lives beside the router, wired straight in.
Node is on wire in the walls running back to the router.
There’s an unmanaged switch between the Node and the router. I can try without this in the chain.
Hi @Aidan_Nolan,
Here’s what we see in the most recent logs.
The prebuffer short reads with all Tidal content, including much smaller 16/44.1 FLAC files. The downloads of these tracks time eventually time out, but Roon has often sufficiently buffered lower-quality content to maintain the audio stream.
With much larger files like 24/192 FLAC, the accumulated failures are often sufficient to end the audio stream.
Unfortuantelt, this is a repeat of our findings in the last log set - this Windows machine isn’t maintaining a connection to Tidal’s servers with sufficient bandwidth to download these files in time to play them back with Roon.
Have you tried changing the DNS server in the router settings page? If it’s something default from your provider, try switching to Cloudflare (1.1.1.1).
I can probably set it in the properties of the network adapter in Windows.
Will give that a try.
Tried the above yesterday evening with Cloudflare settings and no change.
I’ll look at the routers configuration next.
From memory it’s very limited though.
Any other suggestions welcomed.
Hi @Aidan_Nolan,
Certainly, let us know how it goes! My apologies if I’ve glazed over this - do you run into the same issue when streaming content from Tidal directly, completely outside of Roon?
