Amelie
(Amelie Degehet)
March 14, 2022, 1:14pm
#1
Roon Core: Synology DS220+ (10Go Ram)
Macbook Pro (M1 - Monterey - 16Go Ram)
Router Synology RT2600 (wifi or ethernet)
Bluesound Node 2021
22600
Hi,
Since yesterday, I can no longer send music to the Bluesound or other devices… except the “System output”
We see that the lines move, but the title doesn’t start
Could you help me to solve this problem?
Amélie
Sorry for my basic english, my language is french
Have you done the basic troubleshooting like rebooting everything?
Amelie
(Amelie Degehet)
March 14, 2022, 1:19pm
#3
I restarted the macbook and the Bluesound
I would switch the entire network path off from router to client and then switch everything back on starting at the router.
Amelie
(Amelie Degehet)
March 14, 2022, 1:39pm
#5
@ged_hickman1
I turned on and off the Modem, the Router, the Synology and the devices.
It works
Thanks for your help
Amélie
Amelie
(Amelie Degehet)
March 14, 2022, 1:50pm
#6
@ged_hickman1
I wrote too quickly…
By clicking on another album, the problem is there again.
Amelie
(Amelie Degehet)
March 14, 2022, 1:59pm
#7
However, with the BluOS Controller application, it works very well.
Rugby
(aka Daniel or Big Dan)
March 14, 2022, 5:05pm
#8
Hi Amelie,
It might help support to have a screen pic of the Settings Audio page.
Amelie
(Amelie Degehet)
March 14, 2022, 7:16pm
#9
@Rugby
Hi,
Here’s the screenshot
Thanks for your reply,
Amélie
Rugby
March 14, 2022, 7:27pm
#10
Hi Amelie,
Does this happen with only Tidal source? If you play a local album does it have the same issue?
Amelie
(Amelie Degehet)
March 14, 2022, 7:37pm
#11
Hi Rugby,
It happens with Tidal and local music (Synology)
Amelie
(Amelie Degehet)
March 15, 2022, 6:44pm
#12
Hi,
Does anyone have the solution to my problem?
I haven’t been able to use Roon for a few days.
Merci
Amélie
Rugby
March 15, 2022, 6:48pm
#13
Hi Amelie,
I am pinging @support for you so that they can engage. They may be able to look at your logs and see if they can see an issue.
beka
March 17, 2022, 3:05pm
#14
Hey @Amelie ,
One more question before we involve our technical team: could you please check if there is any firmware available for your Bluesound Node and update it if applicable?
Also, a big thank you for letting us know of the issue and replying to everyone’s extremely helpful questions. Special thanks to @ged_hickman1 and @Rugby
Amelie
(Amelie Degehet)
March 17, 2022, 7:04pm
#18
Hi @beka
It works recently
After doing some tests, the problem came from reading the AAC files on my Synology DS220+
I followed the procedure with ffmpeg. It’s ok
Amélie
Rugby
March 17, 2022, 7:06pm
#19
Not beka, obs. But, glad to hear you got it working!
beka
March 17, 2022, 7:25pm
#20
That’s amazing to hear! Thanks for all the effort you put in
system
(system)
closed
March 19, 2022, 7:25am
#21
