Hi. I am new to Roon, coming from Audirvana Studio (which I respect, but it is buggy and the Remote is a pain).
I am getting no sound when I enable anything regarding MQA. I play Tidal out from core to JPlay driver, over Asio. I‘d also like to upsample every rate to 192k - the rest of my chain is well with it.
Audirvana can do this, fyi.
Roon Core: Asus board, Hexacore i7, 16 GB DDR4, M.2 SSD, 3 LAN, OS MS Server 2012 R2 Essentials, Audiophile Optimizer 3.0, JPlay 6 in dual PC setup (separate Audio PC).
Audio PC: Low power Xeon, 16 GB & Server 2012 feeds Mutec MC-3+USB - total 8 of them downstream (seriously! You should hear it!), all 8 synched to Mutec Ref.10 SE Master Clock.
No Tracks in Library, only Tidal and Qobuz.
I understand Roon incorporates a software MQA decoder and renderer to the first stage, 96/24. I’ve read then the output can still be upsampled by DSP to my preferred 192k.
Thanks in advance.
Regards, Peter
Update: It looks like I am hearing MQA - see screenshot. Do you confirm?
No idea how I paste the picture here.
Looks correct to me but why are you upsampling MQA? I think this will break the rendering stage (assuming the DACs that are attached to (or built in to) your audio devices support rendering). MQA is going to get upsampled during each unfold anyway so I don’t know why you would need to do further upsampling.
Many thanks. That was only the bloody beginner’s question. Meanwhile I understand that the MQA Settings in Output regard the following DAC and not Roon Core.
I am fine now, muchas gracias. Why I upsample: The rest of my chain (The separate JPlay Audio PC, then 8 x Mutec MC-3+USB driven by Mutec Ref.10SE clock, Trinnov ST-2 HiFi Room Optimizer, Grimm CC-1 and finally T+A DAC8 sound best at 192 kHz.
