No sound when playing DSD devices. Everything appears to playing normally - signal path shows DSD. But there is no sound. Everything works normally with non DSD files. Have not changed any setting. Antipodes K22 is set to play DSD (DOP).
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
2
Do you get any error messages?
I ask because at just 0.9x processing speed it looks like it is falling down on trying to play that sample rate.
Realistically you need to be at 1.2x or above to play successfully.
Can you try at say DSD128 instead?
Thanks. The DSD256 was an oversight on my part - but it doesn’t even play DSD128 files, which I know the MA3 supports and as indicated by your screen shot as well.
How is the Antipodes K22 connected to the DAC?
The manufacturer specifies different DSD rates for the individual outputs for the device. Does DSD64 work? (For Toslink, DSD may not seem to be possible at all)
The Mietner is Roon Ready but the Antipodes is a way better server/streamer than the built in Streamer in the MA3. The K22 is connected by AES to a Denafrips DDC (GAIA) and AES to the MA3 DAC. I’ve played DSD without issues in the past using a Lumin U1 Streamer into the GAIA to the PS Audio Direct Stream DAC by AES. I’ve not changed any settings in Roon in both set ups.
