I have installed and reinstalled Roon Core for the first time and am trying to connect from both ipad pro and iphone. Both see the PC on which Core is installed but neither will connect. I have typed in the IP address and even switched off the firewall. I cannot figure out what else is causing the issue. Roon Core is running as expected but no use if now useable on a Roon Remote.
The ipad and iphone both show “connecting” continually recycle the same message with “connection failed”
Have you tried closing down roon remote on the ipad and restarting it again. If I have not picked up ipad for a while and it has been playing for an hour or so, when I start using ipad again sometimes have a “trying to connect” problem which is solved by doing the above…
