Not receiving sound
Hi, i can receive sound using pc as the source but can’t receive anything else in other rooms.
Set up seems to be fine but no sound in my living room, bedroom etc.
It seems you only have AirPlay devices (Zeppelin)?
If you enable them and give them a name they should be visible. And do not set them as private because then a device is only visible from that device. You normally use that for phones/tablets.
What hardware is the audio device used in the Zone that you have named as “master”?
Hi @francois_dizarny,
Please accept our apologies for having missed your initial inquiry.
If you’re still experiencing this problem, try refreshing RAATServer and let us know if it changes or relieves symptoms at all:
You can generate a new RAATServer instance on your device by following these instructions, but please be aware that this will reset your Roon Settings → Audio Tab to factory settings and I would advise making a backup of any custom DSP settings you have:
  • Create a Backup of your current Roon database
  • Exit out of Roon
  • Navigate to your Roon’s Database Location
