NUC8I7BEH 16g ram Critical 2 8g new modules +new Samsung 970 EVO Plus 256gig M2 SSD. 6TB external GDrive with its own power supply. USB 3.0
Direct connect wired to Amplifi Alien routerConnected Audio Devices
Using Win 10 PC with RoonBridge connected to a Denafrips Pontus 2 DACNumber of Tracks in Library
49000 TracksDescription of Issue
So the problem in a nutshell…
Updated the BIOS on NUC to latest 0090. * Configured the BIOS Legacy.
Booted from a USB drive with Roon Rock with Etcher installed it.
Booted fine installed ROCK onto the SSD fine, ROCK found the drive no problem installed it all went fine it seemed.
Pulled the USB drive and on reboot it said install proper boot device…
F2 back into BIOS showed the M2 drive as 1st boot device.… advanced show M2 drive just fine all looked good…secure boot off Legacy boot on only USB boot checked…
Re-downloaded the ROCK from your site and redid the USB boot drive and reinstalled again exact same problem…
Boot activity light on NUC showed activity as ROCK was loaded So I tried loading a Linux distro call Zorin 16 on M2 drive and again found drive and loaded software but again would not boot to that either…s ame issue.
Pulled the M2 drive out and installed a std 256GB SSD Intel Blue I had laying around followed the same procedure and it booted up fine and is up and running no issues at all… looks to be some kind of settings issue with the M2 drive but the BIOS etc found the drive no issue and the software loaded to it fine too just no boot… what do you think?
I would try another M2 drive but I don’t have one at hand. F10 into boot showed the M2 drive only there as well. Everything looked fine and correct but it just would not boot from the drive but would read and download to it.
