Hi skbe,
If it is only for Sound quality You do not need to buy formation audio.
Cheers
Frederik
Hi skbe,
Cheers
Frederik
Hi Frederik. Thanks for your input. Much appreciated.
Did you manage to notice a difference when you stream with Roon to your Audio (as a master) and then to your Duos? Is it better/worse/different/same than when you stream with Roon directly to the Duos?
I am very curious to know your feedback on this. Best
Did you notice any difference in sound quality when Roon streams to the Audio and then the Audio streaming back to the Duos?
That’s exactly the question I am asking. Hope we will get some insight
I have answered this question.
To my ear
No difference in audio quality.
Frederik Likaj
thanks for clarifying Frederik
I’m also very curious to find out
The Formation Duo wireless speaker uses cutting-edge technologies like Carbon Dome Tweeter-on-Top and Continuum drivers to deliver the audio quality Bowers & Wilkins is renowned for. Wireless hi-res sound, without compromise. . .
