Nucleus + - updated and rebooted
TEXT GOES HERE
Wired Network.
BT Hub connects to internet
Netgear gigabyte switches between nucleus and Pro-Ject
ProJect connected to Cambridge DAC
TEXT GOES HERE
Project Stream Box Ultra connected to Cambridge DAC.
TEXT GOES HERE
Pro-Ject Stream box visible on my network to my PC and clearly connected to the internet and the Nucleus.
Not identified as an audio device in Roon
Pro-Ject has been updated
Images show a schematic of my network and a screen shot of my network deviceson my PC
Hi Henry. All of these things were turned on. After posting I spent rather more time than I had before browsing the threads around this piece of equipment. I found out that there’s a Roon enable tab buried in the setup on the Pro-Ject app. This must have been enabled when I first set it up and it worked but then turned itself off after a software upgrade perhaps. I’ve just found it now. Roon enabled all works fab.
Thanks for your help
Peter
