My iPad and computer will connect to the nucleus. However, the nucleus will not connect to a audio device. The audio device screen is empty, so no choices are availble
Our diagnostics server show that your Nucleus was recently online, but the server indexed no tracks in the entire Roon library. Are you having issues with your Roon library or streaming services? What do you see on the Roon home screen?
Can you please share the following to equip our team to assess this case further?
a screenshot of the Settings → Audio page within Roon itself from either the iPad or the computer
Thanks for the screenshots and additional information! From a fresh Roon Server diagnostic report, we actually caught an unfortunate case of database corruption on your current Roon Server.
You mention you’ve also lost your library, do you by chance have a saved backup available?
This would be your best option to see if you can revert to an earlier version of your database prior to when the corruption occurred.
Here is more info on backups:
Let me know if you’re able to get a backup restored, and if it also helps with your audio page settings. We’ll review a fresh diagnostic report at this time as well to check its health. We’ll be monitoring for your reply
Database corruption means that during background indexing, Roon Server noticed accumulated changes to the underlying database that shouldn’t be there.
It doesn’t mean the hardware or the Nucleus One’s ability to run software in the future is compromised. It also doesn’t mean your underlying music library is damaged in any way (your tracks and albums are fine, as are any streaming accounts you’ve synced to Roon).
What it does mean is that you can’t restore your play history, custom settings, and other information stored in your database without also restoring the corruption. This puts you in an unfortunate position in terms of curation: you’ll essentially need to rebuild your Roon library from scratch, starting a new database and then importing all your music once again.
The fastest way to do this is to to use the “reset” button in the Nucleus web admin page.
Let us know if this helps; we’re happy to answer any questions.
