Product: Nucleus
Connected to Integra AVR (essentially an Onkyo) via an audioquest HDMI cable.
The unit works well initially, but eventually will not output HDMI audio.
The AVR says analog on the screen, instead of the usual HDMI.
I used to have an intel NUC rock unit that did the same.
When I connected the Nucleus, I re-purposed the NUC as a kodi box (Libreelec).
It initially had the same problem, and I believe an underlying linux update fixed it (to latest nightly builds).
Are there any work arounds available? At the moment, I need to reset the Nucleus to get sound back.
I may try a HDMI EDID modifier to see if that works.
Thanks,
Alex
