Rename the “RoonServer” folder to “RoonServer_old”
Restart the RoonServer in the WebUI to generate a new Database
On the Roon Remotes, press “Use another Roon Server” and connect to the new database
In case you have any issues accessing the Nucleus via the SMB, we have a step-by-step guide on how to adjust this setting in Windows so you can copy your music files:
Please give those steps a try and let me know if you are able to connect afterwards!
This thread is now closing due to inactivity, but you can reactivate it anytime by submitting a new tech support request here. Thank you!
For context, the SMB guest access process @vadim has shared in the post above resolves the vast majority of network share credential issues with Windows-based Roon setups.
