Nucleus not starting with no output on HDMI display (ref#BX9OJ9)
Is Roon Server running?
· Roon Server is on, but I'm still having trouble connecting.
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I don't see Roon Server.
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· *Nucleus*
· *Mesh networks*
You mentioned a mesh network in your setup. Certain common mesh networks might require slight reconfiguration to support Roon.
· Orbi
Click below for next steps with an Orbi mesh network.
· I still need help.
My Nucleus will not start. I have connected it to display via HDMI and see no output.
Orbi mesh network. Nucleus is connected to Orbi base by ethernet.
Hi @Terry_Murray,
Thanks for writing in to let us know about this issue. The symptoms you describe are usually indicative of a hardware failure in your Nucleus. Please use this typeform to begin the RMA process for your Nucleus.
